Reply To: Blender 3.4 – Skin modifier
Forum Archive Blender 3.4 – Skin modifier Reply To: Blender 3.4 – Skin modifier
#77836
    The skin modifier is a bit finicky, you have to massage the vertices for the mesh to settle where it is most beneficial to you. In other words, move them vertices a bit, as you see the mesh changing you yourself decide where to leave it. As far as I know, there is no exact science to it. Marking a vertex as root makes a lot of difference though, that’s the red lined ring you refer to. So move the root around and see where you get the best results. The “Mark Root” button is in the modifier. Also the mark loose button helps settle things.
