I’m not sure what you mean, as you don’t have any texture on the model at this stage.
Can you share a screenshot of the issue?
It may be caused by double vertices or flipped normals, before beveling, press A in edit mode to select all the vertices and then M and select merge by distance, then press SHIFT+N to recalulate the normals.
Try the bevel again and see if it fixed the issue
