Reply To: Bevel Modifier won’t work
Forum Archive Bevel Modifier won’t work Reply To: Bevel Modifier won’t work
#94048
    Hi Ann @awehrman ,
    Most likely a matter of disabling the Clamp Overlap in the Bevel Modifier:
    Depending on your model, you might also have some so-called ‘double Vertices’ ( Select all with A and then M > Merge > By Distance), that are causing problems.
