@vaculik Ah, I just noticed that you’re talking about the high poly object instead of the low poly object. It’s definitely because there are some vertices that are too close together, but that shouldn’t matter if you switch the limit method the weight and add the edge bevel weight manually (not vertex bevel, that’s easy to do by accident).
