Reply To: Bevel Mod + Subsurf Mod flow results in artifacts on edges
Forum Archive Bevel Mod + Subsurf Mod flow results in artifacts on edges Reply To: Bevel Mod + Subsurf Mod flow results in artifacts on edges
#38736
Kaj Suominen
    some areas you’ll still need holding edges to fix problems like that. What you have to remember with the bevel is that it only transform the edge you mark. it doesnt create holding edges across the mesh like when you add them manually.
    its a balancing act in the end.
