Seems like you have vertices that are not merged. Select everything with A and then M to merge by distance.
There might be a couple more things going on, but first try that.
You might also have inner faces or maybe vertices that are not one on top of the other so the merging might not work. If you can, share the .blend file so we can troubleshot it better.
