Hi Thanks a lot Martin
To confirm my understanding: It would have been better if my bevel (for the teeth cut-outs), would have had one or 2 vertexes less, as then they would have been spaced out more?
In other words, the problem is regardless the scale (apply scale was done). I would have had the same issue if I would have made a console much bigger? (instead of e.g dimension of 10 cm, made one of 10 meter big)
For my own learning, I will restart and do the tutorial, and first start with teeth mark and related bevels before doing anything else… So to play around, confirm and learn!
Regards
