Reply To: Best Way to Create Smoothly Integrated Ears and Rounded Boolean Mouth
Forum Archive Best Way to Create Smoothly Integrated Ears and Rounded Boolean Mouth Reply To: Best Way to Create Smoothly Integrated Ears and Rounded Boolean Mouth
#96900
    Hi @Blendash ,
    First do the easy part, make the head and ear, you can simply use some Modifiers in the right order, for instance:
    Then, when you’re happy with the result, Apply all Modifiers on the head and do the mouth. Booleaning it will be easy, but then you’ll probably have to Apply that Modiifer as well and create the last Bevels manually in Edit Mode.
