Thanks for the good feedback.
@csehz Yes, sorry I can’t join more often, time is always the problem. I work 8-5 job and then have freelance work to do in my free time. I’ll do my best trying to keep up with the homework assignments.
@smurfmier1985 My theory is that lighting and color grading are key when it comes to achieving realism. Have never been able to perfectly understand that though. But it also has to build up to that moment, because in order for the light to interact good, you need good shading or material creation, and you need a good modeled model that has no surface wobble with good UV’s.
I learned everything I know watching @theluthier tutorials and others at CG Cookie, boy what I would have given for direct access to the teachers when I was starting up, this live streams are a perfect way to consolidate everything you’ve learned from watching the recorded tutorials. Like the delicious dessert after you have eaten your vegetables.
