Reply To: BC1-1908 Homework – Katerina Novakova
Forum Archive BC1-1908 Homework – Katerina Novakova Reply To: BC1-1908 Homework – Katerina Novakova
#49681
Katerina Novakova
    WIP 1: Barrel stave
    I have a simple scene in mind that I want to create with the barrel (or do I hear barrels?). I want to make them stylized, but with realistic measurements, so I set out to hunt for barrel dimensions. I found those quickly enough. In gallons. And liters. And special wood-working magic units that have been passed from father to son for generations. In centimeters? Not so much.
    But in the end I found something believable, and, equipped with some extra reference, I started from a cylinder with 12 divisions (I hope to separate these into planks later). To get the right shape, I added a circle with the right measurement, positioned it in the middle of the barrel and scaled the mid section to meet the circle.
    Then I deleted the head (that’s barrel jargon for you, ha) and the bottom and I added the Solidify modifier. Remembered to apply the scale (I always forget) and I ballparked the plank width (so much for accurate measurements). I thought about the hoops and realized that it might be a good idea to mirror the barrel on Z (I had to reset the origin to the centre to make this work). And so the barrel stave was born.
