Reply To: BC1-1908 Homework – Katerina Novakova
Forum Archive BC1-1908 Homework – Katerina Novakova Reply To: BC1-1908 Homework – Katerina Novakova
#49689
Katerina Novakova
    WIP 4: Adding top/bottom and a rack
    To create the lid, I added a new circle. I had to experiment a bit with the number of vertices (16 proved to be what I was after). First I filled it with a single face and then I inset it – to get nice shading later. I deleted the middle face and used a grid fill tool with span of 1 to create the planks. Then I selected all the loops and bevelled them with 1 extra edge. To select the middle edge only, I found out the quickest way was to press Ctrl -. Then I ripped those edges again.
    I also applied the mirror on hoops and rivets and made small adjustments to make the mirror less obvious. This is what the barrel looks like now (with MatCap):
    Next I’m going to create a couple more items to put together a simple scene.
