@mrheist To be quite honest, I just skipped over your post now, I will read it completely after today’s Livestream, but you mentioned the order of operations, and one thing I learned, is that it is easier to separate the planks as late as possible.
If you separate the planks and then start making loopcuts, you’ll be making 18 (or whatever number) cuts. If you first make the cuts and then separate the planks… You get the point;)
