OK, so can you explain that more? This is an example of my confusion:
So far, working through the sculpting lessons, there’s a lot of pieces where you mask an area you want to work on, then invert the mask. Then, your grab (or whatever) only affects what is under the now-inverted mask.
I get that 100%. Makes total sense.
But then I’ll see our instructor not just masking a spot, but (for lack of a better way of putting it) masking the same spot over and over so the mask in that strip gets darker and darker as he goes over it more and more. I get that part of that is an artist sketching a line instead of just drawing it in one swipe…but does the thickness of application actually matter in this case?
