Reply To: Baking with combined shaders
Forum Archive Baking with combined shaders Reply To: Baking with combined shaders
#85633
    Did you try baking it? You should be able to bake it either way I think. If not. you can at the end of the chain, just plug the BSDF you need the info baked to. So if you need the diffuse, maybe just add a Diffuse BSDF for the baking info to be piped through? But I think what gets baked in the combined is whatever goes into the surface output? I’m not sure. Try and report what happens Nat.
