I took a look into my special access and was able to find the removal and installation of the top piece. While I can’t explain everything I can explain that the angle bracket is indeed straight. and has a unique flat shape. I’ll flatten the piece and move it over to the side like since it is indeed not centered in between the two top pieces. I’ll see if that helps.
