Reply To: At ~3:30, you use the inset tool on the top of the cube, and it gives you four trapezoid shapes around the outside. When …
Forum Archive At ~3:30, you use the inset tool on the top of the cube, and it gives you four trapezoid shapes around the outside. When … Reply To: At ~3:30, you use the inset tool on the top of the cube, and it gives you four trapezoid shapes around the outside. When …
#21889
rendrag
    Sure, here’s two:
    The cube before I use inset:
    https://www.dropbox.com/s/7kz9c7dlkwrtnhg/indentissue-before.png?dl=0
    And the cube after I use inset:
    https://www.dropbox.com/s/4kdssqzxfcjn6wv/indentissue-after.png?dl=0
    I’m guessing I did something hinkey to the object while playing with it, as if I create a brand new cube and do the inset on it, it works as expected.
