Reply To: Asset Library Reference Path Issue
Forum Archive Asset Library Reference Path Issue Reply To: Asset Library Reference Path Issue
#100324
Radwan Almsora
    Blender Asset Library Path Solution
    Hello,
    To fix this issue and ensure your Feather Generator tool works seamlessly across different Blender versions without manual path troubleshooting, you have two professional approaches depending on how you want to manage the asset dependencies:
    Method 1: Embed (Pack) the Essential Node Groups Directly
    The cleanest way to prevent broken paths across major updates (like migrating from 5.0 to newer versions) is to completely sever the absolute file path dependency and internalize the required nodes.
    • Step 1: In your current project, go to the Outliner and switch the display mode to Blender File.
    • Step 2: Expand the Node Groups section, find the specific procedural hair node groups you are using, right-click them, and select Clear Asset (if they are marked as assets).
    • Step 3: Ensure they are fully localized into your file by selecting them and choosing Make Local if the option is active.
    • Step 4: Save your .blend file. Once internalized, Blender will no longer look into the C:\Program Files\... directory of a specific version, and the asset will load perfectly on any user’s machine regardless of their install path.
    Method 2: Use Relative Internal References (Asset Libraries)
    If the system nodes must remain linked as external references rather than duplicated inside your file, you should avoid absolute directory structures.
    • Instead of linking directly to the installation folder’s .blend file path, utilize Blender’s native Essentials asset library designation if the nodes are part of Blender’s default built-in shipping toolset.
    • Ensure your asset paths are set to Relative Path (indicated by a // prefix in the file path field) rather than absolute local disk paths (C:\...). This tells Blender to search relative to the current runtime environment rather than a hardcoded folder structure.
    Recommendation: For commercial product distribution, Method 1 (Internalizing the Nodes) is highly recommended. It guarantees 100% plug-and-play stability for your customers, eliminating any dependency on version-specific internal folder structures.
    Best regards,
