Reply To: Artifacts left by boolean in 5.0
Forum Archive Artifacts left by boolean in 5.0 Reply To: Artifacts left by boolean in 5.0
#98354
    It is common for booleans to misbehave. Try moving the boolean object a little bit and you’ll most likely see things adapt as you move it. Also once you upload some screenshots we will see the issue better and see what else might be going on.
