Reply To: arm rig retry
Forum Archive arm rig retry Reply To: arm rig retry
#101034
Wayne Dixon
    Hi Samy,
    Yes the bones need to be placed in the correct spots.
    Often this is in the middle of the volume – which isn’t anatomically correct but it will give you a  better result and more flexibility.
    The really important placement is where the joints will pivot.  You want this to be in a logical spot.  For example, the knee joint on one of the earlier submissions was part way down the shin.  This will create really odd looking deformation.
    When a limb has more than one deformation bone (eg – Shin_01 and _02).  These should be aligned or you will have warping in its rest position.
    You don’t want the Shin to bend in it’s default state – this means it will be even more warped that starting model is.
