Reply To: Applying Scale to Curve question
Forum Archive Applying Scale to Curve question Reply To: Applying Scale to Curve question
#85081
    HI Nougat,
    I am glad you asked; that is an excellent question!
    As a rule, I’d say: “Do not Apply the Scale to a Curve!” It either has little to no consequence (as in your example), or it messes things up (for instance when using a Curve Modifier).
    With Meshes, you should (almost) always Apply the Scale, so maybe it was indeed a habit that Jonathan sometimes Applied the Scale to a Curve.
    Now, I do not know everything (of course) and it is possible, that there are scenarios, where you should Apply the Scale of a Curve, but I don’t remember ever having come across a situation like that.
