HI Yukino.
What kind of node setup was it?
Material, World, Texture, Animation Node Tree?
When you append data to your file, it will add the data but it does not apply it to anything. So you will still have to do that manually for whatever you want it to apply to.
Also make sure that you are using the correct version. If the name already exists in the current file, Blender will append a .001 to the end of the name.
EG – if there was already a World called “World”. And you append a World with the same name, the new one will be called “World.001”.
Also watch out for Blender removing any unused data blocks. If it’s not being used and you save, it will be kept when you close the file. So click the shield (fake user) for any data that you want to keep in your file.
Hope that helps.
