Reply To: animation problem
Forum Archive animation problem Reply To: animation problem
#45027
Phil Osterbauer
    @yukinoh1989 hmm so you’ve removed the animation on the root bone and are now keeping it in one place. So you should have a ball that is not moving at all. You will need to turn off your keyset because its looking for “available” key frames because the body does not have animation on it yet. From there you should be in a place where you can start animating with that body control. You’r saying that is not working?
