Reply To: Alt tool to select edges not working
Forum Archive Alt tool to select edges not working Reply To: Alt tool to select edges not working
#90342
Leo
    This is actually a standard shortcut.
    You could look under Preferences (CTRL + ,) and then under Keymap and at the top under Name search for Loop Select to see which shortcut is stored there (see picture)
    The other possibility would be that your edge ring is interrupted, double vertices or similar
