Reply To: all my faces are 3d what happened?
Forum Archive all my faces are 3d what happened? Reply To: all my faces are 3d what happened?
#60293
    You asked what happened 😉
    To revert use Undo (CTRL+Z) a few times. If that doesn’t take you back far enough:
    Go to Front View and with Vertex Select  and in Wireframe Mode select one half and delete it and the select the rest and extrude on X-axis.
    Can’t see what your X Mirror is doing though, but the trick should work anyway, just don’t delete the ‘mirror-line’ vertices.
