Reply To: After applying the material to the first plant, I notice that the underside of it becomes white. It seems to be being caus…
Forum Archive After applying the material to the first plant, I notice that the underside of it becomes white. It seems to be being caus… Reply To: After applying the material to the first plant, I notice that the underside of it becomes white. It seems to be being caus…
#24744
Jonathan Lampel
    Great question, it’s reflecting the white ground which is a bit unnatural of a setting, so you could change the color of what it is reflecting. When it’s in dirt than it won’t look so odd. Or, you could use the Geometry node and Backfacing factor to cut out reflections from the underside altogether if need be.
