@spikeyxxx …Solved! Damn, I must have been really stupid — it was a modifier stack issue. I was applying the Boolean before the Bevel, and that’s what was causing the problem.That weird line issue was solved by switching to the Exact solver. Interestingly, the line was disappearing even when I was just aligning one of my Boolean objects. But yeah, some areas weren’t beveling properly — switching to the Exact solver fixed that too.
Thanks, mate!
I added a cylinder, then applied an Array modifier along the X axis. After that, I duplicated the array stack along the Z axis — so that became one stack of a Boolean object.Then I used Alt+D to make another instance, so now there are two Boolean objects. I put both of them into a collection and used that collection as the full Boolean object. I know my explanation might be a bit messy, but I said that because you asked if there were two Boolean objects.
Anyway, thanks a bunch for always helping!
