Reply To: A lot of subdivision points
Forum Archive A lot of subdivision points Reply To: A lot of subdivision points
#60748
Louis du Mont
    You could isolate them by selecting the straight lines, then shift-h, then merge by distance. ‘M’ and select ‘merge by distance’. A tooltip appears at the bottom left of the viewport where you can adjust the threshold to reduce the vertices.
