Reply To: 7:13 – why not just scale down the size of the leaf so it doesn’t clip?
Forum Archive 7:13 – why not just scale down the size of the leaf so it doesn’t clip? Reply To: 7:13 – why not just scale down the size of the leaf so it doesn’t clip?
#82150
Adrian Bellworthy
    Correct – all the leaves would be too small.
    Applying to a larger object, you need to make sure the scale is applied, and you may need to make adjustments until you get something you like.
    The examples here are exactly that, examples. Every situation will require tweaking in some way.
