Reply To: 7:13 – why not just scale down the size of the leaf so it doesn’t clip?
Forum Archive 7:13 – why not just scale down the size of the leaf so it doesn’t clip? Reply To: 7:13 – why not just scale down the size of the leaf so it doesn’t clip?
#82151
    As Adrian says, it’s just an example for teaching, materials and textures will depend on each situation and if you’re reusing a material, you’ll need to adjust depending on each situation. And then there’s texture resolution that needs to be taken into account, your texture can get pixelated depending on how far or close you are, so there’s a couple of things to be aware of.
