Also a consideration: 8GB VRAM is not that much; depending on what you use Blender for, you might run into situations, where you have to switch to CPU, because your GPU runs out of Memory. So it might be better to combine the 2, if possible.
And I’d also go for 64 RAM, but not with 2 different brands, if possible. Also prefer DDR5 over DDR4. That being said, Blender isn’t very heavy on the System Memory these days, so 32GB might go a long way, depending on the complexity of your Scenes and what else you do (Browsers, for instance, can use up a lot of RAM).
