Thing 2.79 didn’t have but 2.8 have by default and that I find slightly irritating:
> Auto perspective is set to On by default on Preferences > Viewport. Which means that everytime you toggle between front/rear/side view and another one, it changes the view from orthographic to perspective (and vice versa). I recommend turning it off, it’s better for my nerves at least.
> The Undo function is still random (but I assume it’s more a bug than a feature 🙂 )and you have to pray all the CG gods everytime you undo. Avoid frantic Ctrl-Z is what I figured is the safest way to go at the moment.
> If you have transparent materials in Eevee they can appear black or mess with the backface culling setup. So you need to change the Blend Mode to Alpha Blend (or whichever result suits you the most) and check or uncheck backface culling.
(this is obvioulsy not a rant, the overall experience with 2.80 is still very good)
to be continued…
