Reply To: 2.8 Hurdles and Roadblocks
Forum Archive 2.8 Hurdles and Roadblocks Reply To: 2.8 Hurdles and Roadblocks
#47660
    @smurfmier1985 Wait, c’est le bit confused.
    So the radius option will disappear once I make an action with the sun, it’s on of those things that you only get one chance? Does the radius affect the shadow? Spikey said no, so what does the radius do? Also what if I change my mind of the radius later? I’d be radiusless then.
    Then the angle is a different thing then, but I see it affects the shadow the object cast on the floor, but it doesn’t seem to change the shadow on the object… also does changing the angle apart from affecting the softness and hardness of the shadow, does it affect the direction the light shines?
    The real sun is complicated enough man.
