Forum Archive › 2.8+ Background Images › Reply To: 2.8+ Background Images
Thought you could toggle the mesh appearance in material preview, but apparently not the case.
You can use the same trick I showed earlier, just give the Mesh a Material and set the Blend Mode to Alpha Blend:
Is that sort of what you wanted?
