Forum Archive › When I switch from edit mode to object mode, the triangles disappear › Reply To: When I switch from edit mode to object mode, the triangles disappear
Ah, I see! You’re having the same issue as another user. Check out the solution found here: https://blog.cgcookie.com/forums/topic/here-is-how-you-find-length-display-in-blender-2-8/
